overlaying tracks
Help for Audacity 2.x.x on Mac OS X.
ImageThis forum is for Audacity 2.x.x on Mac OS X 10.4 and later.
overlaying tracks
Permanent link to this post Posted by ClarityCoaching » Sat Jul 08, 2017 2:09 pm
I am new to using Audacity. How do I overlay 4 tracks so that they play simultaneously. I have each track separately recorded and saved. Also, how do I import an mp3 file to play simultaneously over the verbal track? Thanks
ClarityCoaching
Re: overlaying tracks
Permanent link to this post Posted by Trebor » Sat Jul 08, 2017 8:53 pm
ClarityCoaching wrote:How do I overlay 4 tracks so that they play simultaneously. I have each track separately recorded and saved ...
You can drag-n-drop multiple tracks into Audacity ...
click on this image to see it in its entirety
Drag-n-Drop files into Audacity.gif (725.23 KiB) Viewed 313 times
The tracks will play simultaneously.
With multiple-tracks you'll probably have to reduce the gain-slider on each of the tracks,
as otherwise their combined volume will be too much and cause clipping distortion.
With multiple tracks playing at the same time you'll probably be in need of Audacity's envelope tool to vary the volume ...
Trebor
Return to Mac OS X
Who is online
Users browsing this forum: No registered users and 2 guests
