I'm editing an interview (all voice, no music) and the guest's sibilance is very bad. I've poked around various support boards- including here - and the most frequently-recommended fix is Spitfish.
I've downloaded the whole Fish Fillet package, and moved the plug-ins to the proper folder. I can see them when I pull down the Effects menu. Using Add/Remove Plug-ins, I see them in the list and click Enable. But they don't show up in the Effects menu, and when I reopen the menu, they've reverted from Enabled to New again.
More poking around, and I found this. It's an .ny file, and I'm still trying to figure out how to open it.
Questions, from ideal fix to least ideal:
- How can I enable Spitfish?
- if that's not possible - what do I use to open De-esser.ny?
- if both are no-go: can you recommend another de-esser? The less complicated the better, I'm no pro here!
Of course I'm on deadline. I appreciate all wisdom you can offer, and speedy wisdom all the more!
