Record from cassette deck to MAC
Help for Audacity 2.x.x on Mac OS X.
ImageThis forum is for Audacity 2.x.x on Mac OS X 10.4 and later.
Permanent link to this post Posted by listenagain » Wed Jul 05, 2017 5:38 pm
Audacity version 2.0.6 Mac OSX Yosemite 10.10.5
How can I record from cassette deck to my Macbook Air? There is no jack input only a headphone socket.
listenagain
Operating System: OS X 10.10 Yosemite
Re: Record from cassette deck to MAC
Permanent link to this post Posted by Trebor » Wed Jul 05, 2017 8:58 pm
listenagain wrote:How can I record from cassette deck to my Macbook Air? There is no jack input only a headphone socket.
~$30 gadget which converts a USB-socket into a line-in ...
( not unique : other such devices are available )
Trebor
Permanent link to this post Posted by listenagain » Wed Jul 05, 2017 11:24 pm
Thanks I'll look around - that link says not available in UK
listenagain
Permanent link to this post Posted by Trebor » Thu Jul 06, 2017 9:55 am
listenagain wrote:... that link says not available in UK
There are UK sellers ...
https://www.amazon.co.uk/s/ref=nb_sb_noss/261-6248966-1484232?url=search-alias%3Daps&field-keywords=UCA202
Trebor
Permanent link to this post Posted by listenagain » Thu Jul 06, 2017 10:09 am
Thanks I found some you've been very helpful
I wonder whether the attached device would also do the trick?
External Stereo sound adapter
listenagain
Permanent link to this post Posted by Trebor » Thu Jul 06, 2017 11:20 am
listenagain wrote: I wonder whether the attached device would also do the trick?
Those are smaller & cheaper, but they don't say "line-in", they just state "mic-in",
( "mic-in" is too sensitive for the output from a cassette-deck, need a "line-in" socket on the recording device for that ).
''line-in'' not mentioned, only ''mic in''.png (186.23 KiB) Viewed 586 times
https://www.amazon.com/UGREEN-External- ... B01N905VOY
Trebor
Permanent link to this post Posted by steve » Thu Jul 06, 2017 12:43 pm
listenagain wrote:I wonder whether the attached device would also do the trick?
It may, but we have no idea what the quality of that device is like. As Trebor wrote, the mic input may be massively overloaded by a tape output, causing it to distort horribly.
The Behringer UCA 202 and UCA 222 have standard RCA connectors for input and output, which make it easy to connect to standard hi-fi equipment, mixing desks and other equipment. The case is only plastic but is reasonably robust, and there are many good reports on this forum regarding reliability and sound quality. They also have a headphone socket so that you can directly monitor what is being recorded.
I have a UCA 202 myself, and my only criticism is that there is no input level control, which is not a problem unless recording a very loud source (my CD player can output a higher level than the UCA can handle, which causes a little distortion on very loud CDs, but I can record via my hi-fi amp which works fine). I've been using the device almost daily for about 10 years, and the only fault is that the label has fallen off.
Permanent link to this post Posted by listenagain » Thu Jul 06, 2017 2:28 pm
Ok very helpful. My tech is not good so what do I need to do if I get the UCA?
My cassette deck has a line in and line out sockets & currently connected to the tuner/amp. So how do I connect to the UCA and computer? and will I be able to monitor the sound when I make the connection? Please assume I'm a little old lady in your answer! Thanks in advance!
listenagain
Permanent link to this post Posted by Trebor » Thu Jul 06, 2017 3:13 pm
listenagain wrote:... So how do I connect to the UCA and computer? and will I be able to monitor the sound when I make the connection?
Picture courtesy of Koz
You'll need a cable to connect UCA to your cassette-deck.
The cable currently connecting cassette-deck to the amp will do if it ends in 2 RCA connectors, and is long enough to reach your computer.
Trebor
Permanent link to this post Posted by listenagain » Thu Jul 06, 2017 3:27 pm
Great. What's the cable that connects to the computer? I can see that one end is a normal USB. What's the connector at the other end. I'm guessing RCA ie those red & white thingys
listenagain
Next
Return to Mac OS X
Who is online
Users browsing this forum: No registered users and 7 guests
