New track added each time REC is pressed
Help for Audacity on macOS.
Thomas Rooth
Post by Thomas Rooth » Fri Jun 23, 2017 3:34 pm
MAC OS Sierra 10.12.5
Hi,
After installing Audacity 2.1.3 a new track is added each time REC is pressed! This means when pressing STOP button for changing side of the LP and then press REC again to continue recording a new track is added below the first one. Is this correct?
This happen also when I start from a blank panel choosing New track in the drop down menu. A New track is shown but when pressing REC another track is added. I expect that recording will start on the first added track I made from the drop down menu!
Can't remember this happened in the previous version of Audacity!
Kind regards
Thomas
Re: New track added each time REC is pressed
Post by kozikowski » Fri Jun 23, 2017 4:06 pm
You can either P pause the recording and then P start it up again, or Stop the recording and Shift-R append record.
