I recorded a gig of our show and split it into 32 labels consisting of 2 1/2 hours of material. When I use the 'export multiple' to send it into iTunes, it only exports the first 13. Any ideas of why?
I'm using El Capitan 10.11.6 with Audacity 2.0.5. I recorded the show using a Tascam recorder and am just trying to split it into separate songs while editing out the talk in between.
Thanks.
Export Multiple Labels not exporting all
- Quality Assurance
Re: Export Multiple Labels not exporting all
Audacity 2.0.5 is very old. I suggest you try with the current Audacity 2.1.3 from http://www.audacityteam.org/download/. Only labels in the uppermost label track are exported.
Thanks! I hadn't realized it was an old version. I updated and it started working.
