For some reason I can not access gsnap vst anymore I even enable it from add ons menus and it still doesn't work.
What should I do?
Plug-Ins
Re: Plug-Ins
First step, you claimed to be on Windows 10 and you posted in the Mac forum. Which one's right?
Which three-digit Audacity version do you have?
