Running multiple Yeti Mics
Help for Audacity on macOS.
Varignon
Post by Varignon » Wed May 24, 2017 4:39 pm
Does any body know how to get two. Blue yeti mics to work on a Mac Book Pro using Audacity. For some reason Audacity only recognizes one of them and not the other.
Re: Running multiple Yeti Mics
Post by steve » Wed May 24, 2017 4:47 pm
Varignon wrote:Does any body know how to get two. Blue yeti mics to work on a Mac Book Pro using Audacity. For some reason Audacity only recognizes one of them and not the other.
Google search for:
Mac aggregate device
Post by Gale Andrews » Thu May 25, 2017 1:16 pm
This does not have anything directly to do with the topic you posted in about a single Snowball mic on Windows, so I started a new topic for you.
Does Applications > Utilities > Audio MIDI Setup recognise both Yetis? If not, device aggregation won't work. I am expecting the Mac will only see one of the mics if they are identical, due to an Apple limitation. See Problem with 2 of the same USB microphone.
The upshot is you may have to send the mics back to Blue to be given unique USB identifiers.
