How do I write-protect a particular track?
Help for Audacity on macOS.
allelopath
Post by allelopath » Sat Apr 22, 2017 4:04 pm
I have the track selected, and then I go to the Tracks menu, but don't see what I'm looking for.
Re: How do I write-protect a particular track?
Post by Gale Andrews » Sat Apr 22, 2017 4:14 pm
You don't, in Audacity.
What are you trying to do, exactly? Make a copy protected CD, for example? Export the track as WAV then prevent other users on the computer using that WAV?
allelopath
Post by allelopath » Sat Apr 22, 2017 7:20 pm
I started with just one track, a recording of a conversation between me and another person. Now I want to created another track that consists of just my voice and then another track consisting of her voice. So, first I created another track which will have only my voice. Now I'm going to cut&paste the sections that are just my voice from track 1 to track 2. As I do this, I want track 1 to be write protected or locked such that I don't modify it as I'm working.
allelopath
Post by allelopath » Sat Apr 22, 2017 7:36 pm
I've started with one track. I've created another, empty track. I will copy&paste bit from track 1 to track 2. As I do so, I want track 1 to be locked so I don't inadvertently make any changes to it.
Post by kozikowski » Sun Apr 23, 2017 12:10 am
There is no locking for individual tracks. We generally recommend exporting a WAV sound file of anything critical. If it's multiple tracks, select each track and File > Export Selected.
Past that, Audacity can't help you with surveillance, evidence production or law enforcement.
allelopath
Post by allelopath » Sun Apr 23, 2017 12:16 am
The what now? How did you get to there?
Is the inability a conscious design decision? Is it not something needed often?
Post by kozikowski » Sun Apr 23, 2017 1:10 am
I don't remember another request for locking a track. The other elves may have.
You have all the markings of someone preparing a deposition, an evidence display or conflict presentation.
allelopath
Post by allelopath » Sun Apr 23, 2017 3:25 am
Nope. You've had 3 law-related guesses. Try 3 others, less weighty.
Post by steve » Sun Apr 23, 2017 10:29 am
allelopath wrote:Try 3 others, less weighty.
I've got a better idea: Rather than us guessing, why don't you tell us what exactly you are trying to do?
allelopath wrote:I've started with one track. I've created another, empty track. I will copy&paste bit from track 1 to track 2. As I do so, I want track 1 to be locked so I don't inadvertently make any changes to it.
To "protect" the track, you could make a backup copy of the track. To do that, select the track, then "File menu > Export Selected Audio", and give the file a unique name. As double insurance, you could make the backup "read only" (https://support.apple.com/kb/PH18894?locale=en_US)
Post by Gale Andrews » Sun Apr 23, 2017 3:09 pm
Locking a track to prevent any editing has been asked for just once before. Note this would prevent you cutting, which is what you said first time.
There have been more requests that that to prevent accidentally time shifting a track. Is that what your concern is?
