Crackling sound over voice - Help!
Help for Audacity 2.x.x on Mac OS X.
ImageThis forum is for Audacity 2.x.x on Mac OS X 10.4 and later.
Permanent link to this post Posted by mnwildfan » Tue Mar 14, 2017 5:13 pm
Hey guys. I need help! I'm producing a Podcast for two hosts who record remotely. One is using a PC and the audio sounds excellent. The other is using a MAC and there's a crackling sound over his voice throughout the episodes. His recording levels are good so it doesn't seem to be a clipping issue. I can send a clip so you can hear what I'm talking about. Has anyone run into this issue before? Because the clicking is on top of the voices, it's pretty much impossible to clean it up so we're dumping great content.
Microphone: Blue Yeti USB Mic
Audacity: Latest version
Computer: MAC
mnwildfan
Operating System: Windows 7
Re: Crackling sound over voice - Help!
Permanent link to this post Posted by kozikowski » Tue Mar 14, 2017 6:18 pm
There is a forum post with the mostly likely culprits.
viewtopic.php?p=322355#p322355
Permanent link to this post Posted by kozikowski » Wed Mar 15, 2017 12:52 am
Each portion of the show arrives as a very high quality, individually-recorded sound file, right? Hopefully, not MP3....
If your only show work is a mixed final from all the performers, you can stop reading now. It's hopeless.
There may be a way to partially rescue that one voice file. There are tools to get rid of pops and clicks in a phonograph recording. The "car hair" filter. And there are unpublished tools that can be used to get rid of lip smacks or "wet mouth noises" (I love that phrase). It's worth experimenting with those in order to save the show.
viewtopic.php?p=245549#p245549
http://manual.audacityteam.org/man/tuto ... iques.html
Return to Mac OS X
Who is online
Users browsing this forum: No registered users and 7 guests
