Can't find "Sound Finder" [SOLVED]
Help for Audacity 2.x.x on Mac OS X.
ImageThis forum is for Audacity 2.x.x on Mac OS X 10.4 and later.
Permanent link to this post Posted by daudac » Mon Mar 06, 2017 10:30 pm
Hi, I can't find the "Sound Finder" feature. It used to be under "Analyze", but after updating to MacOS 10.12.3 and Audacity 2.1.2, I can't find it anymore. Thanks.
daudac
Re: Can't find "Sound Finder"
Permanent link to this post Posted by kozikowski » Tue Mar 07, 2017 10:09 am
Analyze > Add/Remove Programs > Select All > Enable > OK.
Permanent link to this post Posted by steve » Tue Mar 07, 2017 10:25 am
Have a look in the Generate menu. Do you have "Pluck" and "Risset Drum"?
If not, then check to see if "Nyquist" effects are enabled in Preferences > Effects.
Permanent link to this post Posted by daudac » Tue Mar 07, 2017 10:51 am
I appreciate the responses.
I don't see "Pluck" and "Risset Drum" in the Generate menu. In the Preferences menu, Nyquist is enabled.
However, after following Koz's suggestion, I noticed that the "nyquist prompt" path remains disabled. No matter how many times I enable it, it remains disabled. It's also the only plugin that has an empty Name field.
daudac
Permanent link to this post Posted by steve » Tue Mar 07, 2017 12:26 pm
Ensure you installed Audacity correctly and are not running it from the DMG: http://forum.audacityteam.org/viewtopic.php?f=47&t=75660.
If that does not help, it is probably Gatekeeper interfering, so you will need to do the following: Open /Applications/Utilities/Terminal.app. Copy the below text then paste it into the terminal:
Code: Select all
sudo xattr -r -d com.apple.quarantine /Applications/Audacity/
Hit ENTER to send the command. Type the admin password when prompted. You won't see the password while typing it, but hit ENTER when you have finished typing it.
Then reboot.
If Audacity is installed somewhere else than /Applications/Audacity, change the path to reflect where the Audacity folder is.
Re: Can't find "Sound Finder" [SOLVED]
Permanent link to this post Posted by daudac » Tue Mar 07, 2017 6:25 pm
Solved! The sudo command fixed it.
Thank you Steve and Koz. This will be a huge time saver.
daudac
Return to Mac OS X
Who is online
Users browsing this forum: No registered users and 8 guests
