Mac not detecting turntable when I plug it into USB
Help for Audacity 2.x.x on Mac OS X.
ImageThis forum is for Audacity 2.x.x on Mac OS X 10.4 and later.
Permanent link to this post Posted by jasonlloren » Mon Mar 06, 2017 1:21 am
I'm running Mac OS X 10.10.5 and Audacity 2.1 on my MacBook Air. When I plug the turntable into my laptop using the USB cable, my mac doesn't detect the device. Help!
jasonlloren
Operating System: OS X 10.10 Yosemite
Re: Mac not detecting turntable when I plug it into USB
Permanent link to this post Posted by Gale Andrews » Mon Mar 06, 2017 2:04 am
jasonlloren wrote:I'm running Mac OS X 10.10.5 and Audacity 2.1 on my MacBook Air. When I plug the turntable into my laptop using the USB cable, my mac doesn't detect the device. Help!
We don't make 2.1 - all versions have three numbers (please see the pink panel at the top of the page).
If your Mac does not detect the device, that's the end of the story. Have you tried a different USB cable, and made sure that it is tight at both ends? Try rebooting with the turntable switched on and the cable tightly connected.
Permanent link to this post Posted by jasonlloren » Mon Mar 06, 2017 4:09 am
2.1.0
jasonlloren
Permanent link to this post Posted by Gale Andrews » Mon Mar 06, 2017 4:19 am
jasonlloren wrote:2.1.0
Thanks for the version number. It's a little old, but not the cause of the problem.
Permanent link to this post Posted by jasonlloren » Mon Mar 06, 2017 4:30 am
Rebooting didn't help. I'll have to try another cable, I guess.
jasonlloren
Permanent link to this post Posted by billw58 » Mon Mar 06, 2017 6:38 pm
Is the turntable powered on?
-- Bill
billw58
Return to Mac OS X
Who is online
Users browsing this forum: No registered users and 10 guests
