Help for Audacity on macOS.
Audacity 1.2.x and 1.3.x are obsolete and no longer supported. If you still have those versions, please upgrade at
https://www.audacityteam.org/download/.
The old forums for those versions are now closed, but you can still read the archives of the
1.2.x and
1.3.x forums.
LukeB
Post
by LukeB » Wed Feb 15, 2017 12:45 am
Hi guys,
I've recently started recording church sermons.
Everything starts out fine and then some time in (say 20 mins or so) a crackling can be heard, and as time goes on is slowly gets worse. The crackling is only present when the voice is there (i.e. not in the silences). The audio is coming straight from the mixing desk and the crackling is not heard through the sound system.
Here is a sample of what I'm talking about:
http://elfuzzo.websiteconnection.com.au ... sample.wav
Attached is a screenshot of some of the above sample - spikes can be clearly seen although the crackling is happening in throughout the whole thing and not just on the spikes.
- crackling_audio_screenshot.png (26.75 KiB) Viewed 7022 times
I'm using Audacity 2.1.2 on El Capitan and all other programs are closed while recording.
If anyone has any suggestions to help with this it would be much appreciated
Post
by kozikowski » Wed Feb 15, 2017 4:22 am
The download gives me a File Not Found.
What's the computer? I'm typing this on a Mac Mini.
LukeB
Post
by LukeB » Wed Feb 15, 2017 5:13 am
Sorry about that - I've just fixed the sound sample link.
I'm using a Macbook Pro for recording.
cyrano
Post
by cyrano » Wed Feb 15, 2017 8:56 am
Download works here and now...
Sounds like loss of sync. USB?
What's the mixing desk and the interface between it and the computer?
LukeB
Post
by LukeB » Wed Feb 15, 2017 12:10 pm
I'm using one cable between the mixer and the laptop - no USB in between.
It's a 2xRCA <===> 3.5mm stereo cable connecting from an RCA output on the desk straight to the line-in on the laptop.
LukeB
Post
by LukeB » Wed Feb 15, 2017 10:22 pm
Hi Gale, thanks for that.
So I've made sure the MIDI line in settings and Audacity sample rate & bit depth match each other (44.1kHz and 24-bit), and I've selected "prevent app nap" for Audacity, so I'll see how things go this weekend.
Since the first week's recording was fine (no crackling for any of it) I'll leave the buffer setting as it is after making the above changes, and if it's still causing dramas I'll change that for next weekend.
Thanks for your help guys - I'll let you know how things go after Sunday.
LukeB
Post
by LukeB » Wed Feb 22, 2017 7:17 am
Thanks guys - that seems to have fixed the problem
