SAVE WORK AND START OVER NEXT DAY?
Help for Audacity on macOS.
Canary
Post by Canary » Mon Feb 13, 2017 8:10 pm
I HAVE wINDOWS 10 AND .EXE AUDACITY DOWNLOAD
Is there a way to save ones work and start again next day besides leaving the computer on all night open to Audacity.
I don't know what the three section is
waxcylinder
Re: SAVE WORK AND START OVER NEXT DAY?
Post by waxcylinder » Mon Feb 13, 2017 11:06 pm
Yes use Save Project - and then day open the same prpject.
See this page in the Manual: http://manual.audacityteam.org/man/file_menu.html
