Help for Audacity on macOS.
Audacity 1.2.x and 1.3.x are obsolete and no longer supported. If you still have those versions, please upgrade at
https://www.audacityteam.org/download/.
The old forums for those versions are now closed, but you can still read the archives of the
1.2.x and
1.3.x forums.
- Quality Assurance
Post
by Gale Andrews » Mon Sep 12, 2016 2:32 pm
hollyadams wrote:Changing both to 48000 reduced the frequency of the occurence, but that still means it happens every couple of minutes.
Are you sure you followed every single step here
http://alphamanual.audacityteam.org/man ... ac_crackle ?
If none of that helps, try recording in GarageBand or some other app and see what happens. If you still receive clicks, ask Presonus about the problem. Perhaps they did not fix the problems they had in previous El Capitan after all.
hollyadams
Post
by hollyadams » Mon Sep 12, 2016 3:33 pm
Thank you so much! i will try Garage Band, and I do have an inquiry in to PreSonus.
You have been amazing--thank you so very very much.
