Audacity Menu
Help for Audacity on macOS.
Re: Audacity Menu
Post by Gale Andrews » Mon Aug 15, 2016 12:44 pm
Niku wrote:I don't see a way to answer each person who has posted something.
To do that, press the "QUOTE" button in the post you want to reply to.
waxcylinder sent the link to http://manual.audacityteam.org/man/tool ... rview.html.
Toolbars are not in the Audacity Menu Bar, which is what you asked about.
Niku
Re: Audacity Menu
Post by Niku » Mon Aug 15, 2016 1:16 pm
Gale,
Well, thanks for that. That's something that never would have occurred to me. Most sites use REPLY. As to the menu-tool bar issue, to me, the "menu is everything at the top, including the tool bar. However, since others may have your understanding of the issue. I'll keep it in mind.
