Audacity won't open because of Debbuging report
jerrycurl2323
I've tried to install Audacity a number of times. I follow the correct instructions to install it and when I open Audacity, every time it tries to send this Debugging report and then I can't ever open it. How do I fix this problem?
Re: Audacity won't open because of Debbuging report
Audacity or the debugging report?I can't ever open it.
Post the report on the forum.
http://forum.audacityteam.org/viewtopic ... 49&t=64936
Audacity doesn't ever open enough to give you an error message?
Did you get your Audacity from here:
http://www.audacityteam.org/download/mac/
jerrycurl2323
I open the audicity app and the first thing that appears is a debugging report. Whether I send a debugging report or cancel it, it disappears. Then if I try to open the app again the Debugging report appears again. And yes, I did download it from there.
Ummmm.
Well, shucks.
Are you an administrator on your computer?
[X] Allow user to administer this computer
You went through the installer graphic where you dragged the tasteful Audacity icon to the tasteful Applications icon? I think it even works if you drag it to the real Applications folder if you know how to drill down that far.
Did your Mac object to installing a non-Apple application?
Well, shucks.
AFAIK, Audacity doesn't send reports.jerrycurl2323 wrote:I open the audicity app and the first thing that appears is a debugging report. Whether I send a debugging report or cancel it, it disappears. Then if I try to open the app again the Debugging report appears again. And yes, I did download it from there.
I think that is an OSX crash report.
And it's normal that it disappears after sending or canceling. You can still find the crash reports by opening the application called "Console" in Applications/Utilities/ and clicking on "crash reports" in the left pane of the window.
Posting it here should give us some idea why Audacity is crashing something.
jerrycurl2323
Here's Debug report pic, sorry it's sideways
Reason: rotated the image
jerrycurl2323
Someone please help
Yes that error message has come from Audacity,
If you could post those three debug files they may provide some indication of what the problem is.
See here for how to attach a file to a forum post: http://forum.audacityteam.org/viewtopic ... 49&t=64936
jerrycurl2323
I really don't know how I'd post these files here. Is there just any definitive explantation as to why this is happening? Am I the only one to have ever experienced this?
It's because something on your computer is making Audacity crash. On crashing, Audacity is attempting to generate a bug report that will hopefully give some indication of what it is that is causing the crash.jerrycurl2323 wrote:Is there just any definitive explantation as to why this is happening?
No your not the only one, but thankfully it is quite rare.jerrycurl2323 wrote:Am I the only one to have ever experienced this?
Are you able to find the files on your computer?jerrycurl2323 wrote:I really don't know how I'd post these files here
If so, how to attach files to posts is described here: http://forum.audacityteam.org/viewtopic ... 49&t=64936
If you still have difficulty posting the files please be as specific as possible in describing the problem so that we can advise as necessary.
