Audio noise when trying to record a vinyl record to Audacity
Help for Audacity on macOS.
billw58
Re: Audio noise when trying to record a vinyl record to Auda
Post by billw58 » Sat Dec 16, 2017 7:11 pm
blad wrote: Thanks Bill I've included the specs for the NAD 1155 pre-amp. If you can make a conclusion from these regarding what output would be the best for Audacity please advise.
Those specify maximum output levels, not nominal. Just connect it and try it out.
-- Bill
