OK, that's much clearer (to me) than saying that the split line ensures a smooth fade with no further explanation.steve wrote:yes, that's correct, but a significant difference between the two is that when there is a split, the first song will always fade to silence, and the second song always fades in from silence.Gale Andrews wrote:I am saying that in the selection after the crossfade (now 2s to 5s) I can only hear tone (which is visibly and audibly slightly fading out) from 2s to 3s. I hear no noise until 3s.
If there isn't a split, then one of the fades will either start or end abruptly unless the selection contains exactly the same length of the first song and the length of the second song.
Thanks for the images.
