In my opinion, now that (in Audacity 2.1.3 alpha) we have in "Crossfade tracks" the "Automatic" setting for fade direction, "Crossfade Tracks" is the better effect to use. The main advantage of "Crossfade Tracks" is that it allows the user to precisely set the overlap that becomes the crossfade. However, we have many users that insist on putting their mix into one single track as they work - the Crossfade Clips effect is primarily for those users.Gale Andrews wrote:I can't see the point in that unless it's essential to have only one track or unless you are one of the "challenged" who want to just click and not make any decisions.
Yes the Crossfade Clips effect can be used if you have a file with several songs one after the other, and using Crossfade Clips is very quick and convenient for this type of task as long as you are not concerned about the "overlap" being precise. In such a case, my workflow would be something like this:
1) Import the file.
2) Identify the end of the first 'song' / start of the second 'song'.
3) Select any silence, or "nearly silent" gap between the songs and "Split Delete". If there is no noticeable 'gap' between the songs, then I'd just add a Split line between the songs.
4) Select across the split line, roughly 50/50 and apply the Crossfade Clips effect.
Looking at what happens with close attention to technical details:
The manual states:
If you judge your selection accurately enough, then there is no need for a split line, but if you misjudge, then you probably won't get what you want.If the selected region is continuous audio with no splits, the first half and last half of the selected audio will be crossfaded.
Let's say that you misjudge quite badly and select 60/40 (%) rather than 50/50 (this is close to a 'worst case scenario' for no splits)
If there is a split line:
The first 60%, from the start of the selection to the split line, will fade out.
The final 40%, from the split line to the end of the selection, will fade in.
The two audio clips are then overlapped such that the fade-out of the first track ends at the same time as the fade-in of the second track ends. (The tracks are always overlapped such that silent end of the longer fade occurs at the same time as the loud end of the shorter fade - this ensures that only the faded regions overlap.)
The second track therefore does not begin to fade in until a short time after the first track has started fading out. However, this 'error' is hardly noticeable. The effect is very forgiving in this case.
If there is no split line:
In this case, as the manual says, the first 50% will fade out and the second 50% will fade in.
However, if we have misjudged the mid-point and the first song runs for 60% of the selection, then the first 1/5th of the fade in (which should be the second song, is actually still the first song, and by the time that the second song starts, we are already 20% into the fade-in, so the second song does not fade from silence. This can be demonstrated by crossfading a tone into white noise. In these files (attached), the source material was 5 seconds of 440 Hz tone followed by 5 seconds of white noise. The selection was from 2 seconds to 7 seconds (3 seconds before the end of the tone, to 2 seconds after the end of the tone - a 60/40 selection).
Listen to how the noise fades in.
We should probably have a tip to say that it is generally best to have a split between songs, but I don't think we should go into detail about all this "under the hood" stuff. Do you think you could work that in somehow?
