Recovered files are mute, no project
Help for Audacity on macOS.
martent
Post by martent » Sun Dec 27, 2015 11:48 pm
Hi,
I'm running Audacity 2.1. My Mac is running 10.11.2. Unfortunately I should say because this is sort of the problem, or rather: my now mute recovered files/projects that hadn't been saved before a new OS was installed, without asking permission, by other user on same Mac..
My directory is in /var/folders/0t/hc4mll0x43jfth8tcs8_cv1w0000gp/T/audacity-Marten
Attached is the log file. Any hope of recovering the actual audio?
Best,
Mårten
Audacity crash MT log.txt
(466.33 KiB) Downloaded 46 times
Re: Recovered files are mute, no project
Post by kozikowski » Mon Dec 28, 2015 1:36 am
There is no 2.1. I hope you mean 2.1.0?
Oh, here it is. 2.1.1.
Is this an edited project or a raw capture from a performance?
Post by kozikowski » Mon Dec 28, 2015 2:03 am
Can you find any of those little AU files?
Code: Select all
20:04:44: Varning: Saknar data blockfil: '/var/folders/0t/hc4mll0x43jfth8tcs8_cv1w0000gp/T/audacity-Marten/project893826679/e00/d02/e0002f1d.au'
20:04:44: Varning: Saknar data blockfil: '/var/folders/0t/hc4mll0x43jfth8tcs8_cv1w0000gp/T/audacity-Marten/project893826679/e00/d02/e00023fb.au'
20:04:44: Varning: Saknar data blockfil: '/var/folders/0t/hc4mll0x43jfth8tcs8_cv1w0000gp/T/audacity-Marten/project893826679/e00/d00/e0000c7a.au'
20:04:44: Varning: Saknar data blockfil: '/var/folders/0t/hc4mll0x43jfth8tcs8_cv1w0000gp/T/audacity-Marten/project893826679/e00/d04/e0004754.au'
The structure is an AUP text file with the instructions to Audacity how to construct the show out of the contents of the similarly-named _DATA folder. The _DATA folder contains a deeper directory structure with the AU files.
The AUP file and the _DATA folder must live in the same location or folder for the show to open.
You should be able to look and see both.
Go (top of desktop) > Go To Folder (see attached).
It's 2.1.1 now. What was it before?
http://manual.audacityteam.org/o/man/au ... jects.html
Screen Shot 2015-12-27 at 17.59.27.png (17.15 KiB) Viewed 788 times
Post by Gale Andrews » Mon Dec 28, 2015 12:09 pm
kozikowski wrote:The structure is an AUP text file with the instructions to Audacity how to construct the show out of the contents of the similarly-named _DATA folder.
Except in this case there is no saved project, so it is the AUTOSAVE file and the "project893826679" folder.
