Version 2.1.1 not opening
Help for Audacity on macOS.
Spooky98
Post by Spooky98 » Mon Oct 05, 2015 5:49 pm
Installed version 2.1.1 today and tried to run. Installed under El Capitan on iMac (21.5-inch, Mid 2011), 2.7 GHz Intel Core i5. Any solution. One was given but, I don't see a 'audacity.cfg in the subfolder for application support/audacity/
Thanks
Dave
Spooky98
Re: Version 2.1.1 not opening
Post by Spooky98 » Mon Oct 05, 2015 6:16 pm
Solved my problem, thanks anyway and have a great day
dave
Post by steve » Mon Oct 05, 2015 6:18 pm
It may be helpful for others if you say what the solution was.
Post by Gale Andrews » Mon Oct 05, 2015 8:37 pm
Also when you have a problem, please post in the Mac board, not in "Feedback and Reviews". More people whom it affects will see it that way. I moved your topic here.
Spooky98
Post by Spooky98 » Tue Oct 27, 2015 3:10 pm
Sorry for not posting in the right area. The problem I was having was Audacity crashing when I tried to open application. I did finally find the audacity.cfg file. After removal of this file, Audacity was able to run and I was able to record. Not sure why a .cfg would cause a problem. Anyway, everything seem to be working.
