TunnelThroughTime wrote:I"ve used the Mix and Render function to check for clipping,
That's generally a good idea, but remember that Audacity projects do not save the "Undo" history.
I would recommend that before you save the project, undo the "Mix and Render" so that your project still has separate tracks (just in case you need to adjust the mix later).
Alternatively, use "Mix and Render to New Track" to check the levels. Then you can either solo the mixed track when you export (to export only the mixed track) or mute the mixed track (to export everything except for the mixed track).
TunnelThroughTime wrote:whether Audacity itself changes any of the gain levels when to Exports files to .Wav or .Mp3
Mute, Track Gain and Track Pan are applied to the exported file in the same way as they are applied to playing the project. The exported file should sound virtually identical to the project (depending on the quality of the format - MP3 and other compressed formats always lose a bit of sound quality).
For "lossy" formats (such as MP3), the peak amplitude may slightly different from the peak amplitude of the mixed track in Audacity. This is because lossy formats are inexact. The difference is usually too small to make a noticeable difference, but you may want to allow a little more "headroom" to your final mix if you intend to make an MP3 version so as to ensure that the peak level does not exceed 0 dB. I generally allow 1 or 2 dB of headroom. 3 dB of headroom (Amplify or Normalize the mix to -3 dB) is virtually guaranteed to be enough to not clip in any format, but is probably a bit excessive.
TunnelThroughTime wrote:I've read that Audacity will produce a Stereo Mix-down when you finally decide to Export the project.
Export will mix down to mono or stereo, depending on the project.
If the project is entirely mono tracks, and all tracks are centre panned, then the show is mono (what plays through the left speaker is
identical to what plays through the right speaker). In this case, the exported file will be mono. Similarly, "Mix and Render" will produce a mono track in this case.
If the project includes any stereo tracks, or if any of the tracks are panned off-centre, then the exported file will be stereo (provided that the file format supports stereo, which most formats do), Similarly, "Mix and Render" will produce a stereo track.
TunnelThroughTime wrote:Hypothetically, this means that the dynamics of a project recorded with 8-tracks would be greater than that of a 4-track recording;
Probably not. The "dynamic range" is the difference between the maximum peak and the level of the noise floor. Increasing the number of tracks will often increase the noise floor, so you need to be extra-careful about minimising noise when using lots of tracks.
