exporting a 24 bit file to 16 bit wav
Help for Audacity on macOS.
mary86004mary
Post by mary86004mary » Tue Aug 18, 2015 12:12 am
If I open a 24 bit file in audacity and export it as a 16 bit wav file. Does that mean it will no longer be wet bits? That it will actually be a 16 bit wav file?
mary86004mary
Re: exporting a 24 bit file to 16 bit wav/ correction of typ
Post by mary86004mary » Tue Aug 18, 2015 1:09 am
typo correction - I am correcting my own typo from my earlier post
If I open a 24 bit file in audacity and export it as a 16 bit wav file. Does that mean it will no longer will be 24 bits? That it will actually be a 16 bit wav file?
Post by kozikowski » Tue Aug 18, 2015 5:11 am
Yes. The dynamic range of the new file will be 16-bit. The same as digital television and audio CDs.
