Generating Blue Noise
Help for Audacity on macOS.
waverlye
Post by waverlye » Fri Jul 31, 2015 7:37 pm
How can I generate blue noise?
Re: Generating Blue Noise
Post by steve » Fri Jul 31, 2015 7:59 pm
Generate white noise, then filter it with the Equalization effect, Use the "Draw curves" mode and make a line from lower left to upper right. The steepness of the slope governs how "blue" the resulting noise will be.
