cut vs delete? Not defined in index or glossary
Help for Audacity on macOS.
Equalizer
Post by Equalizer » Tue Jul 21, 2015 4:02 pm
Probably one removes the selected region permanently from the file, and the other creates a copy of the selected region.
I think my intuitive response is the opposite of the way it works, I'm ending up with only that a little selected bit remaining, when what I want is to remove the selected portion.
What is the difference between cut and delete, as implemented in Audacity?
Re: cut vs delete? Not defined in index or glossary
Post by Gale Andrews » Tue Jul 21, 2015 4:11 pm
Equalizer wrote:Probably one removes the selected region permanently from the file, and the other creates a copy of the selectd region.
I think my intuitive response is the opposite of the way it works, I'm getting a little bit when I want to remove that bit.
Cut removes the selection and adds it to the Audacity clipboard in case you want to paste it.
Delete only removes the selection.
http://manual.audacityteam.org/o/man/edit_menu.html.
