Export Chains
Help for Audacity on macOS.
friendlygiraffe
Export Chains
Post by friendlygiraffe » Sun Jul 19, 2015 11:55 am
Hi,
I have several custom chains I've created that I want to copy to another computer / installation
Is it this possible? At the moment, I'm just redoing them all manually
Thanks
Re: Export Chains
Post by steve » Sun Jul 19, 2015 12:15 pm
If you are using the same version of Audacity on both machines, and have all of the necessary effects installed, then you should be able to just copy over the chain .txt files from the "Chains" folder.
See the bottom of this page: http://manual.audacityteam.org/o/man/edit_chains.html
