Audacity 2.1.1 and OS X 10.10.4
I just updated to Audacity version 2.1.1 on two computers running OS X 10.10.4, and it works on one, but on the other, it won't even open. What further information do you need in order to get to the root of the problem?
Re: Audacity 2.1.1 and OS X 10.10.4
Hardware INFO? One is a 13" MacBook Pro and the other is a 2012 Mac Mini?
Are you sure it did not open? Could it be that Audacity crashed immediately after opening, before any window became visible? Just like in this case: http://forum.audacityteam.org/viewtopic ... 47#p280669chrzaszcz wrote:I just updated to Audacity version 2.1.1 [...]
I don't think it opens at all; when I click on it, the dock icon jumps up and down a few times (if I'm lucky) and then just stops. The black dot never appears underneath it. This is all happening on a 20-inch iMac with a 2 GHz Intel Core 2 Duo processor from mid-2007.
- Quality Assurance
What Audacity version did you update from?chrzaszcz wrote:I just updated to Audacity version 2.1.1 on two computers running OS X 10.10.4, and it works on one, but on the other, it won't even open.
Force Quit Audacity in Activity Monitor if necessary.chrzaszcz wrote:I don't think it opens at all; when I click on it, the dock icon jumps up and down a few times (if I'm lucky) and then just stops. The black dot never appears underneath it. This is all happening on a 20-inch iMac with a 2 GHz Intel Core 2 Duo processor from mid-2007.
Open Finder, choose Go > Go to Folder and type:
Code: Select all
~/Library/Application Support/audacity/ Then delete the audacity.cfg in ~/Library/Application Support/audacity/.
If you added new plugins the last time you ran the old Audacity version, delete the entire "audacity" folder in ~/Library/Application Support/.
Try launching 2.1.1 again.
Please attach the old audacity.cfg you made a copy of, in case we can see a problem in it. Please see here for how to attach files: http://forum.audacityteam.org/viewtopic ... 49&t=64936.
Taking the audacity.cfg file, which is attached as ‘audacity.txt’, out of the Application Support folder seems to have solved the problem. Will I run into any other problems now because I did that?
I updated from Audacity 2.1.0.
- Attachments
- audacity.txt
- (4.92 KiB) Downloaded 32 times
- Quality Assurance
Thank you for the attached file.chrzaszcz wrote:Taking the audacity.cfg file, which is attached as ‘audacity.txt’, out of the Application Support folder seems to have solved the problem. Will I run into any other problems now because I did that?
In fact that .cfg file was last saved by Audacity 2.0.6 and has entries for obsolete preferences that go back to Audacity 1.3.x (autosave interval) and 2.0.0 (cached audio data).
And you were using a non-standard path for the Audacity temp folder.
So it is probably good to start with factory default settings. You may have to relocate FFmpeg. There should not be any other problem. If there are any more problems please let us know.
Renaming the .cfg file and keeping it in the same folder seems not to work but moving it to another folder as suggested seems to do the trick. As this seems to be a general problem with the current OS, it looks like the instruction to move the file should be included in the installation instuctions (alternatively an installer script should do the job but obviously that makes everything more complicated. Or of course an update can be produced that will fix the problem.
I have read all of the above information and I still cannot get the latest version of Audacity to open.
I have deleted all previous versions of Audacity, including the application support library, and it still will not start up.
I looked in the application support library and could not see a file with .cfg anywhere.
I have a Mid 2007 iMac running Yosemite 10.10.4.
I was running the previous version of audacity with no problems whatsoever.
Any advice?
Any advice?
@ RobNY: There are two application support libraries for Audacity. The one that has the .cfg file is the one that you get to starting from your home directory (~/Library/Application Support/audacity).
