track size
Help for Audacity on macOS.
atomottokar
track size
Post by atomottokar » Fri Jun 19, 2015 5:55 pm
hello
Mac pro book os 10 .8.5
is there a way to have automomatically the default track this vertical size
Snap 1 P.png (10.13 KiB) Viewed 647 times
instead of this one
Snap 2 .png (9.69 KiB) Viewed 647 times
thanks to let me know
Re: track size
Post by kozikowski » Fri Jun 19, 2015 7:09 pm
It's not automatic exactly, but you can press Shift-Command-F and all work will fit in the available space. It's part of the View menu.
You know you're in Envelope Tool mode right? The blue lines top and bottom mean you can grab them and change the volume of the track and then change music note by note if you want with multiple click points. That can get in the way if you don't know you're doing that. Change by clicking the "I" button (upper left of the six buttons). That's a more normal editing mode.
atomottokar
Re: track size
Post by atomottokar » Sat Jun 20, 2015 7:39 am
hello yes envelop tool i knew
thanks a lot .
atomottokar
Re: track size II
Post by atomottokar » Sat Jun 20, 2015 7:44 am
by the way it will be nice for futur version
to have the wide just under the pan slider .
anyway in my view
cordialy
Re: track size II
Post by Gale Andrews » Sat Jun 20, 2015 5:18 pm
There is a Preference to "automatically fit tracks vertically zoomed". See Tracks Preferences - Audacity Manual.
atomottokar wrote:by the way it will be nice for futur version to have the wide just under the pan slider .
Sorry I do not understand. Can you explain more?
atomottokar
Re: track size
Post by atomottokar » Sat Jun 20, 2015 6:59 pm
ok no problems
when i load an empty default track the wide of this track stop just under the pan level
when i load a piece to edit the track appear way wider .
in fact i would like it to appear with the same wide as the empty one .
i send a snap ! my english is limited there.
Screen Shot 2015-06-20 at 8.54.38 PM.png (39.45 KiB) Viewed 629 times
Re: track size
Post by Gale Andrews » Sun Jun 21, 2015 4:22 pm
atomottokar wrote:when i load an empty default track the wide of this track stop just under the pan level
That is "height", not width.
atomottokar wrote:wwhen i load a piece to edit the track appear way wider .
Stereo Tracks are twice the height of mono tracks. If you import a mono file its track will be the same height as Tracks > Add New > Audio Track.
Do you want us to add your "vote" for a preference for the default height of mono and stereo tracks?
atomottokar
Re: track size
Post by atomottokar » Sun Jun 21, 2015 8:31 pm
yes please
thanks a lot for all your helpfull answear
Re: track size
Post by Gale Andrews » Mon Jun 22, 2015 3:12 pm
atomottokar wrote:yes please
I added your vote to the Feature Requests page on Audacity Wiki.
