Lock audio clips
Help for Audacity on macOS.
friendlygiraffe
Lock audio clips
Post by friendlygiraffe » Tue Jun 09, 2015 3:16 pm
Hi,
Is it possible cut or paste a segment of audio onto a track without shifting the already existing clips in front of it?
I'd like to lock them at their current time position
Hope that makes sense
Thanks
Re: Lock audio clips
Post by Gale Andrews » Tue Jun 09, 2015 4:09 pm
friendlygiraffe wrote:Is it possible cut or paste a segment of audio onto a track without shifting the already existing clips in front of it?
Yes, providing the audio section you want to lock is in one or more of its own clips. Uncheck Editing a clip can move other clips in Tracks Preferences.
friendlygiraffe
Post by friendlygiraffe » Tue Jun 09, 2015 4:11 pm
That's perfect - Thanks Gale
