edit volume of an imported audio file
Help for Audacity on macOS.
JIMWICK
Post by JIMWICK » Wed May 13, 2015 4:10 pm
I am a novice with audio software. I see that we can cut and paste the imported audio files.
But I want to decrease the volume in specific sections of an imported file.
Since the cut & paste procedures are manual ( visual, horizontal ), :?:
I hoped that volume amplitude was simply a manual visual horizontal action also.
I cannot locate any reference to volume editing in the EDIT drop menu.
Comments are requested and much appreciated.
Re: edit volume of an imported audio file
Post by steve » Wed May 13, 2015 4:15 pm
One way is to use the Envelope Tool: http://manual.audacityteam.org/o/man/envelope_tool.html
Another way is to use the "Adjustable Fade" effect: http://manual.audacityteam.org/o/man/ad ... _fade.html
