Just wanted to test...
Audacity 2.0.1 on OSX 10.9.5
Audio was OK, I was playing soundcloud. I wanted to see if I could reproduce this error.
- OSX was set for 44.1/24 bit. All audio from the browser or itunes gets resampled automatically by Core Audio if needed. This works perfectly with all programs.
- Opened a 4 min. wav (24 bit/44.1 KHz) in Audacity. Export to mp3, VBR, quality 2. Didn't check if it plays in Audacity.
- Opened in iTunes. Played OK till the end.
So, no error reproduced under Mavericks. But then:
- No more audio out from Audacity.
- Checked System preferences/Sound
- Checked and reset Midi/Audio setup.
- Still no audio.
- Restarted.
- Itunes still OK playing the export. Finder plays mp3 and wav. Browser has sound too.
- Audacity still no audio out. Meters show output, but all I hear is a click when starting and a click when ending. Restarted Audacity, didn't help
Logs:
Code: Select all
21/04/15 01:21:05,451 Audacity[29470]: PScurrentwindowbounds: CGSGetWindowBounds returned error (1001) - repeated ca. 200 times over 24 hours.
21/04/15 01:21:05,452 Audacity[29470]: PScurrentwindowbounds: CGSGetWindowBounds returned error (1001)
21/04/15 01:21:05,615 Audacity[29470]: error [1000] setting colorSpace to Kleuren-LCD colorspace
21/04/15 01:21:05,660 Audacity[29470]: _initWithWindowNumber: error creating graphics ctxt object for ctxt:0x913b, window:0x1448
21/04/15 01:21:05,665 Audacity[29470]: _NXPlaceWindow: error setting window shape (1000)Any other things I can test or report?
