Cannot open any file in Audacity [SOLVED]
Help for Audacity on macOS.
ciavyn
Post by ciavyn » Mon Apr 06, 2015 3:11 pm
Hey gang--I've used Audacity successfully for years. I'm helping someone setup a podcast using audacity. We've installed it properly (it's inside its folder in the Applications folder), but when we attempt to open any file, it will not open. Doesn't matter if it's a .mov, .mp4, .mp3...it acts like it's opening the file, gives you the timed dialogue boxes, but then....nothing. No error code, no warning...just a blank Audacity space.
What am I missing? I've never had this happen before, and I've downloaded and installed it on all of my computers without having this problem.
Thanks for any insight.
Tech specs:
Mac, 2014 model, desktop
Version 10.10.2
Re: Cannot open any file in Audacity
Post by Gale Andrews » Mon Apr 06, 2015 3:46 pm
ciavyn wrote:I've used Audacity successfully for years. I'm helping someone setup a podcast using audacity. We've installed it properly (it's inside its folder in the Applications folder), but when we attempt to open any file, it will not open. Doesn't matter if it's a .mov, .mp4, .mp3...it acts like it's opening the file, gives you the timed dialogue boxes, but then....nothing. No error code, no warning...just a blank Audacity space.
Tech specs:
Version 10.10.2
Although one other user has reported something similar on OS X 10.9, it is not a known problem.
Note that Audacity does not open files, it always imports a copy of compressed files like MOV, MP4 or MP3. You don't say what Audacity version or where you got it from. Make sure you have Audacity 2.1.0 from http://audacityteam.org/download/mac.
Please describe exactly how you import the files - do you drag them in, or use open with from Finder, or something else? Please provide some example full paths to the files for example ~/Interviews/April2015/interview.mp3.
Are the files stored on a network?
Where have the files come from in the first place - for example from a specific web site? Please download MediaInfo from http://mediaarea.net/en/MediaInfo/Download/Mac_OS and give us the full text details for some example files that won't import.
ciavyn
Post by ciavyn » Mon Apr 06, 2015 8:22 pm
Hi Gale!
I use it the same way I always have:
I open Audacity, click file>open>go to folder where file is kept. In this case, it was both on Dropbox and the desktop--I tried it both ways. We're able to open and hear the files in Quicktime. Every time, I get the regular opening dialogue showing a timer. Then it goes away, and no folder has been opened. No error, nothing.
We're using the most current version of Audacity for Mac.
Post by Gale Andrews » Mon Apr 06, 2015 9:47 pm
ciavyn wrote:I use it the same way I always have:
Is no track created? Or is a silenced track created?
What does the file selector say in File > Open... - "All supported files" or something else?
What does Help > Show Log... (top right of the Audacity menus) say after you fail to import the files?
You could try dragging the problem files in from the Desktop, avoiding the File > Open dialogue.
More diagnosis - what happens if you Generate > Tone... in Audacity, export it as WAV or AIFF to some folder that Dropbox does not know about, then import that file? If you have LAME then you can try exporting to MP3.
In case this is something to do with metadata or encoding of the file, do please download MediaInfo from http://mediaarea.net/en/MediaInfo/Download/Mac_OS and give us the full text details for some example files that won't import.
ciavyn wrote:We're using the most current version of Audacity for Mac.
It is really important you ensure you have Audacity 2.1.0 from http://audacityteam.org/download/mac and that when you open Audacity > About Audacity... it says exactly 2.1.0.
There can be fake versions of Audacity in circulation and version numbers matter. ;)
chasfred
Post by chasfred » Sun Apr 12, 2015 12:33 am
I have the same problem. Have been using 2.0.6 until moments ago realized upgrad was available. Since downloading and (unfortunately) replacing the 2.0.6 program, the 2.1 will not open, import, or accept drag and drop. Exactly as described above; it goes through the paces as though it is opening the file but then no tracks are created: only a blank grey Audacity box with no indication that it has in fact linked to the file (no file name at the top). Late '07 Mac Pro running Mac OS 10.7.5. Attempting to open the same program on my laptop (to which I downloaded and replaced 2.0.6 also), running Mac OS 10.8.5 yields the following message:" "Audacity" can't be opened because the identity of the developer cannot be confirmed."
If this is a hack it is a very good one: the appearance to all functions is identical; except they don't work.
I hope I can download the earlier version and get back to work.
Post by Gale Andrews » Sun Apr 12, 2015 5:03 pm
chasfred wrote:I have the same problem. Have been using 2.0.6 until moments ago realized upgrad was available. Since downloading and (unfortunately) replacing the 2.0.6 program, the 2.1 will not open, import, or accept drag and drop. Exactly as described above; it goes through the paces as though it is opening the file but then no tracks are created: only a blank grey Audacity box with no indication that it has in fact linked to the file (no file name at the top). Late '07 Mac Pro running Mac OS 10.7.5.
Unfortunately, unless users supply us a concrete example file that has this problem with the full path they are accessing the file from, there is nothing we can do about it, given the problem does not show up on our machines.
Could you help us with that, or give us the information from Help > Show Log... as requested above after attempting to import a file? Are these WAV, MP4 or which format?
chasfred wrote:Attempting to open the same program on my laptop (to which I downloaded and replaced 2.0.6 also), running Mac OS 10.8.5 yields the following message:" "Audacity" can't be opened because the identity of the developer cannot be confirmed.
Please see http://manual.audacityteam.org/o/man/fa ... mac_launch.
chasfred wrote:If this is a hack it is a very good one: the appearance to all functions is identical; except they don't work.
If Audacity > About Audacity... says "2.1" as you say, then it is a hack - it should say exactly "2.1.0". We can't help you with that version because we did not make it. I suggest you use 2.1.0 from http://audacityteam.org/download/mac.
chasfred wrote:I hope I can download the earlier version and get back to work.
You can get the official 2.1.0 or 2.0.6 direct from this trusted download partner: http://www.fosshub.com/Audacity.html.
abailes
Post by abailes » Tue Apr 14, 2015 1:50 pm
I'm having the same problem. I just installed Audacity 2.1.0 on Mac OS 10.7.5. I try to open an M4A file. It goes through the timer. Then nothing. Just a blank window with tools at the top that I can't use because no file is open.
Post by Gale Andrews » Tue Apr 14, 2015 4:05 pm
abailes wrote:I'm having the same problem. I just installed Audacity 2.1.0 on Mac OS 10.7.5. I try to open an M4A file. It goes through the timer. Then nothing. Just a blank window with tools at the top that I can't use because no file is open.
As previously stated, we cannot reproduce this issue.
Therefore there is nothing we can do unless users are able to assist us by doing all of these:
  • Provide a link to an example file, so we can see its name and examine its contents.
  • State the full path to the file. If the file is in your own user space, there is no need to give us your user name, just say "<my user name>" instead.
  • Show us the contents of Help > Show Log... after attempting to import the file.
If no-one does this then the bug will most likely remain unfixed.
Albert_Sjoberg
Post by Albert_Sjoberg » Tue Apr 21, 2015 11:03 am
I have a similar problem to Gale, except I interpret it slightly differently.
Backstory - Long history using Audacity many years ago, and I rocked 1.3. I would like to believe I am not an absolute dunce. Today I returned to Audacity after a long layoff and installed the latest version.
I can import/open a wav file. I can play it (Space-Play/stop) and I can view the mixer/faders.
What I can not do is see, activate or find the normal WAVEFORM display that I have used to select anything.
From the Window menu I can see the file name I have opened. It is marked/Ticked but that is it.
I wonder if this is not the same issue that the original poster, Gale Andrews is having.
It certainly looks like nothing is happening when you do not see the normal waveform display that is present in the wiki and manual.
Is it possible that that subroutine was not included in the most recent build accidentally?
Any help would be appreciated.
Cheers
Post by Gale Andrews » Wed Apr 22, 2015 12:44 am
Albert_Sjoberg wrote:I have a similar problem to Gale
None of us (including me) can reproduce a problem where the file progress dialogue appears but then the waveform does not load. Unfortunately no-one in this topic has been willing to share an actual file with us, give us detailed information about the files or show us the Audacity log.
Albert_Sjoberg wrote:I interpret it slightly differently. Backstory - Long history using Audacity many years ago, and I rocked 1.3. I would like to believe I am not an absolute dunce. Today I returned to Audacity after a long layoff and installed the latest version.
Please see the pink panel at the top of the page. What are all three version numbers of Audacity from Audacity > About Audacity..., and what version of OS X do you have?
Albert_Sjoberg wrote:I can import/open a wav file. I can play it (Space-Play/stop) and I can view the mixer/faders. What I can not do is see, activate or find the normal WAVEFORM display that I have used to select anything.
I am not having this issue. ;)
Albert_Sjoberg wrote:It certainly looks like nothing is happening when you do not see the normal waveform display that is present in the wiki and manual.
Thanks for that. It does sound like the same issue but few people would attempt to play a file you cannot see.
Albert_Sjoberg wrote:Any help would be appreciated.
Once again:
There is nothing we can do unless users are able to assist us by doing all of these:
If we can test an example file that shows no waveform on a user's machine and shows none on our machines, then we can fix it.
If the same file does show a waveform on our machines then we know the problem is something not directly related to the file, perhaps some kind of memory issue. In that case we need to know what type of Mac you have and what version of OS X.
Have any of you tried anything to refresh the window (like dragging it at bottom right, or use the green window button) or to refresh the "waveform" (by applying an effect)?
