I installed 2.1.0 from DMG on my upgraded 10.10.2 MBP last night, opening the DMG and dragging the left icon to the right, and answering "replace" rather than "merge" when prompted.
Got around to running it this morning, and when I click the icon in my dock, the OS tells me that [well, I will be damned; you *can* copy text out of an error dialog; nice goin' Apple]:
“Audacity.app” can’t be opened because the identity of the developer cannot be confirmed."
If I click the help button on that dialog, the page I get says
The app has been modified, and its code does not match the original signed code. The app may be broken or corrupted, or it may have been tampered with. If you think that an app has been damaged or tampered with, you should delete it by dragging it to the Trash.
audacity-macosx-ub-2.1.0.dmg is 34,404,169 bytes
Any thoughts? Is this because I upgraded (/ incorrectly)?
[ edited to correct typos in version number ]
2.1.0 on 10.10.2 won't launch after upgrade [SOLVED]
- Quality Assurance
Re: 2.1.0 on 10.10.2 won't launch after upgrade
Please read this FAQ: http://manual.audacityteam.org/o/man/fa ... mac_launch.Baylink wrote:when I click the icon in my dock, the OS tells me that [...]
Re: 2.1.0 on 10.10.2 won't launch after upgrade [SOLVED]
Yup; that was it. Odd I don't remember having had to do that for 2.0.6.
Sorry for the noise.
