TwinOak wrote:Leland, I will check this out after the Easter holidays, but I have no memory at all seeing an .audacity.sock file in "application support/audacity" on my regular (working) mobile account, which is configured to show hidden files.
A quick google shows no sign that SL-Server wouldn't support sock files. My knowledge about them is very limited though, this is the first time I'm made aware that they exist.
I couldn't find a definitive answer, so I tested it myself. While I don't have OSX Server, what I try to pass off for a brain kicked in and I realized that I can do AFP sharing between two clients...DOH!
Anyway, as suspected, it is failing when attempting to create the socket. Which, after thinking about it, makes sense because Unix domain sockets are meant to be used within a single host.
I don't see a workaround for you unless you want me to build you a private version that relocated the socket file to the users "temp" directory. I assume that would be on the local filesystem???
Leland
