TEAC TN300
Help for Audacity on macOS.
MDCAMG
TEAC TN300
Post by MDCAMG » Mon Mar 16, 2015 4:24 pm
Bought a USB enabled TEAC TN300 turntable but Audacity doesn't seem to recognize the turntable device. It connects through USB and all settings, both on the Mac system and the software are set to USB Codex input. Running Yosemite 10.10.2. Any thoughts?
Re: TEAC TN300
Post by Gale Andrews » Mon Mar 16, 2015 6:10 pm
Audacity won't officially support Yosemite until the next 2.1.0 release of Audacity, which we are working on.
Audacity does not see a USB device if you plug it in while Audacity is running. Try restarting Audacity with the TEAC connected.
audiowave
Re: TEAC TN300
Post by audiowave » Wed Oct 17, 2018 1:38 am
Hi, I'm also bought recently TEAC TN300 with USB from this guide [Advert removed by moderator.], haven't met any serious issues, Audacity 2.3.0 works fine, sometimes I've got spikes of sounds, but it is normal
