using OS X 10.7 its recording from the system mike
new to audacity; how do i shut off whatever recording source that is recording apparently from my Mac Book Pro internal microphone, so my recordings all have background noise, including me cussing and shouting at the machine to stop it:)
thanks in advance
thanks in advance
Re: using OS X 10.7 its recording from the system mike
You don't "shut it off."
What are you trying to do?
i am recording music using the internal mike and when i play it back, i can hear my own voice and the background noise in my room. So it's not just recording the music internally, it's recording "live" as well.
So you want to record sounds that are playing on your computer?duaneg5 wrote: So it's not just recording the music internally,
Mac's can't do that on their own - they require additional software such as "SoundFlower". See: http://manual.audacityteam.org/o/man/tu ... n_mac.html
it records the music fine; but unlike Wiretap i am hearing background noise on the recordings, as though there's a second sound source it's picking up, and the twin red recording levels keep moving when i press the stop-record button, so it's still recording.
On an unadorned Macintosh, Audacity only has one selectable recording audio source:
Internal Mic.
(Well, the analog input may show up too, but that's not germane here)
It may *be* recording the audio that you're playing out the analog output from some other program, but it's going out the speakers and back in the microphone.
Unless you are dealing with some program which cannot, your best bet is to have whatever program is *generating* the audio save it to a file, and then import it to Audacity to edit -- if that was your goal.
Internal Mic.
- Quality Assurance
That's should be impossible on Audacity supplied by us - monitoring is turned off when you stop recording.duaneg5 wrote:it records the music fine; but unlike Wiretap i am hearing background noise on the recordings, as though there's a second sound source it's picking up, and the twin red recording levels keep moving when i press the stop-record button, so it's still recording.
I suggest you download Audacity 2.0.6 from http://audacityteam.org/download/mac.
If you are using Soundflower to record, set Audacity to record like this:
That woulds be the on-line music, right? Like YouTube or other service?it records the music fine;
