[Crashes] 2.0.6 on OS/X 10.10.0
Help for Audacity on macOS.
Baylink
Post by Baylink » Thu Feb 05, 2015 4:48 pm
Gale suggested I post in a new thread the crash reports from some crashes I've had using that combination, which I didn't realize was not actually supported -- I don't recall seeing a warning to that effect, which someone might want to take steps about (even if those steps are merely saying "look, doofus: the warning is right *there*". :-)
A common thread in these crashes is that since it leaves the lockfile in the root of the temporary folder (in my case, not the boot folder, and one which is VFAT, rather than HFS+J, though I don't think that's necessarily pertinent), when it restarts, the application-modal spashscreen blocks your access to the necessary dialog to delete said lockfile, and the only solution is to Force Quit Audacity, and remove the lockfile manually, after which all is well. I infer that might be simply a fix of swapping a couple lines of code, but I have not married the code base, so of course I might be being optimistic.
Baylink
Re: [Crashes] 2.0.6 on OS/X 10.10.0
Post by Baylink » Thu Feb 05, 2015 4:52 pm
I find that "the extension .diag is not allowed".
Is there a standard protocol for uploading these?
Post by steve » Thu Feb 05, 2015 5:07 pm
Baylink wrote:I find that "the extension .diag is not allowed".
It's a text file, right?
If so, change the file extension to .txt
Post by Gale Andrews » Thu Feb 05, 2015 5:13 pm
Baylink wrote:Gale suggested I post in a new thread the crash reports from some crashes I've had using that combination, which I didn't realize was not actually supported -- I don't recall seeing a warning to that effect, which someone might want to take steps about (even if those steps are merely saying "look, doofus: the warning is right *there*". :-)
If you download Audacity from http://audacityteam.org/download/ it says clearly that the OS X support is 10.4 to 10.9.x.
If you look in the Release Notes 2.0.6 - Audacity Wiki it says at the top that 2.0.6 does not support Yosemite.
Baylink
Post by Baylink » Thu Feb 05, 2015 5:18 pm
Well, I guess that's sensible, yes.
Baylink
Post by Baylink » Thu Feb 05, 2015 5:21 pm
Here are a few of the reports.
Audacity_2015-01-20-191853_Jays-MacBook-Pro.wakeups_resource.txt
(94.27 KiB) Downloaded 18 times
Audacity_2015-01-20-193116_Jays-MacBook-Pro.wakeups_resource.txt
(66.4 KiB) Downloaded 18 times
Audacity_2015-01-20-194441_Jays-MacBook-Pro.wakeups_resource.txt
(29.51 KiB) Downloaded 15 times
Audacity_2015-01-20-202015_Jays-MacBook-Pro.wakeups_resource.txt
(29.23 KiB) Downloaded 18 times
Baylink
Post by Baylink » Thu Feb 05, 2015 5:22 pm
Four more
Audacity_2015-01-22-222617_Jays-MacBook-Pro.cpu_resource.txt
(20.71 KiB) Downloaded 16 times
Audacity_2015-01-22-223222_Jays-MacBook-Pro.cpu_resource.txt
(72.21 KiB) Downloaded 16 times
Audacity_2015-01-22-223734_Jays-MacBook-Pro.txt
(739.52 KiB) Downloaded 27 times
Audacity_2015-01-22-224402_Jays-MacBook-Pro.wakeups_resource.txt
(242.56 KiB) Downloaded 17 times
Baylink
Post by Baylink » Thu Feb 05, 2015 5:24 pm
The Final Four<tm>
Audacity_2015-01-22-224811_Jays-MacBook-Pro.cpu_resource.txt
(53.36 KiB) Downloaded 16 times
Audacity_2015-01-23-155756_Jays-MacBook-Pro.txt
(679.69 KiB) Downloaded 18 times
Audacity_2015-01-23-164057_Jays-MacBook-Pro.cpu_resource.txt
(185.11 KiB) Downloaded 16 times
Audacity_2015-02-04-164840_Jays-MacBook-Pro.txt
(730.25 KiB) Downloaded 15 times
Post by Gale Andrews » Thu Feb 05, 2015 5:35 pm
Baylink wrote:A common thread in these crashes is that since it leaves the lockfile in the root of the temporary folder (in my case, not the boot folder, and one which is VFAT, rather than HFS+J, though I don't think that's necessarily pertinent), when it restarts, the application-modal spashscreen blocks your access to the necessary dialog to delete said lockfile, and the only solution is to Force Quit Audacity, and remove the lockfile manually, after which all is well.
After 2.1.0 we're intending to move the lockfile to the directory the audacity.cfg settings file is in.
The lockfile should not be left behind, and the way Audacity handles that (not letting you access Preferences as it suggests) is a bug - but it is a bug generally on at least OS X and Linux.
Where is your temp file exactly - have you changed its location?
Are there any crashes, hangs or force quits other than that? From the file names and looking at two of your files, those are not crash reports but hangs.
Baylink
Post by Baylink » Thu Feb 05, 2015 6:24 pm
That was my whole collection; my temp folder is in the root of a volume on its own partition
