Rikki127 wrote:The only reason I didn't stick with the alpha version is the VU meter was kinda hard on the eyes (I assume that will be fixed?)
I don't think it will be "fixed" because you might be complaining about a deliberate redesign.
Is what you don't like the numbers on the meters?
If so, you can undock the meter by dragging the serrated edge on the left, then drag the meter downwards (at bottom right) until it's the standard height it was in 2.0.6. That will make the numbers appear under the meter bars.
If you have space in the upper dock area you can then drag the standard height meter back into the upper dock.
If you want to discuss this in detail (now or later) please start another topic about it.
