Rikki127 wrote:IT WASN'T SOUNDFLOWER AFTER ALL!
Or at least I don't think so. It's hard to tell now since I've tried so many things. What happened was, after not using Audacity for a couple of days when I tried it again the dropout problem suddenly reappeared!! So of course I'm like all, sunuva -- @#$!%$! So I started from scratch with a new copy of Audacity 2.0.6 for Mac (I think I was last using the beta based on previous suggestions).
Beta versions of Audacity are very old, experimental but nonetheless official releases. We have not released Beta versions for several years.
There is a partial fix for certain Mac playback problems in the latest
alpha versions at the top of
http://www.audacity.homerow.net/index.p ... order=desc. If you want to experiment it is better to use those alpha builds and give us feedback on them.
Rikki127 wrote:Then I tried changing the buffer again, only this time I REDUCED it from 100 to 50 -- and it worked!!! This seemed strange to me because I thought the whole point of a larger buffer was to ease the workload on the CPU. Doesn't lowering it make it harder?
Yes it is counter-intuitive but it is what I was suggesting doing. As I said, I have to reduce Audacity's Audio to buffer myself in the alpha builds, but only if if I set Audacity to use Soundflower as the playback device. There is no longer a constant crackle as there used to be before the fix referred to above, but I get a click when I start playback unless I reduce the buffer.
Most people return the Mac playback device to built-in audio after recording with Soundflower, so they may not hear the problem.
Rikki127 wrote:Another interesting note, I played around with different buffer values to see if I could hear an optimal point of clarity. 25 caused an entirely new kind of distortion or clipping or something (though it would only appear after a period of time of good sound, not right away)
You can't set the buffer too short or the computer won't be able to get back soon enough to top the buffer up.
Rikki127 wrote:You guys might want to delete Soundflower from the topic now?
Are you saying that if you set the Audio to buffer to default value of 100, playback is crackly even if you set the Audacity playback device to built-in audio? If that's the case it would be very useful to let us know if the builds at the top of
http://www.audacity.homerow.net/index.p ... order=desc improve that.
