Amplify Effect in an Edit Chain?
Help for Audacity on macOS.
cpsmusic
Post by cpsmusic » Mon Nov 24, 2014 2:41 am
Hi,
I've just started using Edit Chains for dynamics processing of spoken word material.
When doing this manually I've used Amplify, setting it to -0.5dB. Is there a way to do this using Edit Chains. It seems that the only parameter available is Ratio which will vary the output according to the level of the input. Should I use Normalize instead?
Cheers
Chris
Re: Amplify Effect in an Edit Chain?
Post by steve » Mon Nov 24, 2014 9:34 am
cpsmusic wrote:Should I use Normalize instead?
Short answer: Yes.
Longer answer:
"Amplify" allows you to set how much to amplify by. (Example: Amplify by +3 dB)
"Normalize" allows you to set what level to amplify to. (Example: amplify to -1 dB)
"Normalize" also allows you to correct DC offset. http://manual.audacityteam.org/o/man/normalize.html
