Help for Audacity on macOS.
Audacity 1.2.x and 1.3.x are obsolete and no longer supported. If you still have those versions, please upgrade at
https://www.audacityteam.org/download/.
The old forums for those versions are now closed, but you can still read the archives of the
1.2.x and
1.3.x forums.
juliajmueller
Post
by juliajmueller » Tue Nov 04, 2014 5:05 pm
I have just upgraded Audacity on my Mac after having to get a new hard drive. I am also using a brand new logitech headset. I am hearing a disruptive hummm in the background of my voice track. It is not present on my background music track. How in the world can I get rid of this hum? I am creating a hypnotic recording and have not experienced this before that I recall?
I would so appreciate a timely answer because I must deliver this recording today, with or without the hum
Thank you,
Julia
- Quality Assurance
Post
by Gale Andrews » Tue Nov 04, 2014 6:34 pm
Moved to the correct Mac OS X board.
juliajmueller wrote:I have just upgraded Audacity on my Mac after having to get a new hard drive. I am also using a brand new logitech headset. I am hearing a disruptive hummm in the background of my voice track. It is not present on my background music track. How in the world can I get rid of this hum? I am creating a hypnotic recording and have not experienced this before that I recall?
If it's a USB headset, plug into a spare USB port on the computer or into a wall powered hub.
Mild hum could be removed with Effect >
Noise Removal....
Post
by kozikowski » Tue Nov 04, 2014 7:46 pm
My USB headset does that, too. It's very sensitive to other electronics on my desk. Mine can pick up hum from my large monitor. Try moving around while you listen to yourself.
Post
by kozikowski » Tue Nov 04, 2014 7:48 pm
Another one. Try to wrap the headset cable around your hand and then touch something metal like a desk lamp or the front of the computer. I have one microphone which works perfectly well when I do this.
