Hi,
Is there a quick way to accurately select the area between two clips on a single track?
Boundary guides don't seem to work for this.
I realise this could be done by looking at the end/start times of the two clips but I'm wondering if it can be done using the selection tool alone.
Cheers,
Chris
Selecting the Space Between Clips
- Quality Assurance
Re: Selecting the Space Between Clips
Double-click.cpsmusic wrote:Is there a quick way to accurately select the area between two clips on a single track?
I should have added that the area is empty.
If I double-click the whole track is selected.
- Quality Assurance
The Boundary Snap Guides should work with white space if Snap To in Selection Toolbar is "Off".cpsmusic wrote:I should have added that the area is empty.
If Snap To is "On" then mouse drags (and clicks) will only snap to physical boundaries where the boundaries are at an exact position for the selection format specified in Selection Toolbar. See the bottom of http://manual.audacityteam.org/o/man/bo ... uides.html .
