Best Way to Bandsplit Audio
Help for Audacity on macOS.
cpsmusic
Post by cpsmusic » Wed Sep 03, 2014 1:52 pm
Hi,
I often find myself wanting to apply processing to specific frequency bands. I was wondering what is the best way to split a track into separate tracks containing different frequency bands so that it can be recombined with minimal artifacts?
Cheers,
Chris
Re: Best Way to Bandsplit Audio
Post by steve » Wed Sep 03, 2014 2:28 pm
Is this a question about Nyquist, or about using effects and functions that already exist in Audacity?
Robert J. H.
Post by Robert J. H. » Wed Sep 03, 2014 6:01 pm
cpsmusic wrote:Hi,
Cheers,
Chris
The first step is to duplicate the track according to the number of bands you wish eventually.
Then follows the separation per high/low-pass filtering.
(the code snippets are for the Nyquist Prompt)
- First Track
Code: Select all
(lp s 500)
- Second track
Code: Select all
(hp s 500)
Those are the filters with the flattest slope, i.e. 6 dB per octave and the separation is therefore fairly poor.
You can replace them with those for 12,24, 36 or 48 dB, namely
(high-/)lowpass2, lowpass4, lowpass6 or lowpass8.
Unfortunately, these filters are not complementary--they do not add up to one.
The trick is to use just one of them and to take the difference.
- First track
Code: Select all
(lowpass8 s 500)
- Second track
Code: Select all
(diff s (lowpass8 s 500))
Things get a little complicated when you want multiple bands. You've essentially to redo the previous separation in order to split further apart.
This is due to the phase shifts introduced.
You could also use FIR filters instead of IIRs that do have a linear phase response.
FIR-separation.wav
(931.61 KiB) Downloaded 35 times
(split the example to mono)
cpsmusic
Post by cpsmusic » Thu Sep 04, 2014 12:09 am
steve wrote:Is this a question about Nyquist, or about using effects and functions that already exist in Audacity?
I'm interested in trying the de-essing technique described here:
http://nerds-central.blogspot.com.au/20 ... do-it.html
I wanted to get more info about how to split and recombine the audio while minimising artifacts. I wasn't sure which filters to use or how to set them up.
Post by steve » Thu Sep 04, 2014 1:26 am
Use the Equalization effect. That's an FFT filter so it does not have the phase shift issues that the "High Pass" and "Low Pass" effects have.
