De-esser for Mac?
Help for Audacity on macOS.
kathichild
De-esser for Mac?
Post by kathichild » Sun Aug 24, 2014 5:42 pm
Is there a de-esser for Mac OS X 10.9? I use Spitfish on a PC, but it is not available for Intel-based Macs. Thanks!
Re: De-esser for Mac?
Post by Gale Andrews » Sun Aug 24, 2014 6:25 pm
Try the de-esser in http://mda.smartelectronix.com/ . Please give us feedback on how well it works.
Trebor
Post by Trebor » Sun Aug 24, 2014 11:28 pm
Gale Andrews wrote:Try the de-esser in http://mda.smartelectronix.com/ . Please give us feedback on how well it works.
On Windows I found it is necessary to apply that mda de-esser repeatedly for it to have an effect comparable with SpitFish , so you may have to do the same on the Mac version, [ Keyboard short-cut to repeat the last effect used is "Command"+"R" ]
Tim Lookingbill
Operating System: OS X 10.6 Snow Leopard or earlier
Post by Tim Lookingbill » Mon Aug 25, 2014 8:48 pm
Applying the mda-de-esser defaults suppresses left channel detail that virtually eliminates or at least takes too much away from the stereo imaging. I applied it to the shrill and high pitched pyramiding trumpets section on Maynard Ferguson Awright,Awright I've been demoing over in my '70/'80's CD music remix thread.
I couldn't find a sweet spot setting with the provided three sliders that preserved the stereo imaging. It de-essed the trumpets quite nicely though.
A setting of 10,000hz cut off frequency/-6db resonance in AU LowPass filter did a better job and preserved the stereo imaging.
kathichild
Post by kathichild » Tue Aug 26, 2014 2:35 pm
Thanks for the help. I am a volunteer for an agency that records books for the visually impaired. When I use the mda de-esser, it reduces the volume . but doesn't have any impact on the sibilance. I will keep trying, but if anyone knows of another application, I'd like to try something else.
Post by Gale Andrews » Tue Aug 26, 2014 4:03 pm
kathichild wrote:if anyone knows of another application
There are plenty of de-essers on Mac but as you chose Mac you will have to pay for most of those applications.
Otherwise try cutting the high frequencies as suggested. Audacity has Effect > Low Pass Filter... (under the divider) or you can use the Apple Low Pass or you can use Equalization .
If you need help, post a sample of a phrase you want to de-ess: http://forum.audacityteam.org/viewtopic ... 49&t=72887 .
Tim Lookingbill
Post by Tim Lookingbill » Tue Aug 26, 2014 5:56 pm
kathichild wrote:Thanks for the help. I am a volunteer for an agency that records books for the visually impaired. When I use the mda de-esser, it reduces the volume . but doesn't have any impact on the sibilance. I will keep trying, but if anyone knows of another application, I'd like to try something else.
Another Audacity tool I find can suppress harsh, noisy "S" sounds is Noise Removal.
Close to the bottom of this thread... http://forum.audacityteam.org/viewtopic ... 46&t=80518
...shows NR settings and mp3 sample results that delivered total dead air silence to vocal recordings that had a lot of noise...
You'll have to tweak to get the best roll off between actual voice timbre and "S" sounds. Record or find a mid intensity "S" sound in the audio stream to establish a noise profile and tweak to get the best results.
Tim Lookingbill
Post by Tim Lookingbill » Tue Aug 26, 2014 6:23 pm
Since you're not concerned with preserving stereo imaging I applied mda-De Esser settings (see screenshot) to my edits applied to the vocal sample from that other thread I linked. See if you get the same results.
Lektion90 mdaDeEsser A_B.mp3
(253.57 KiB) Downloaded 150 times
Trebor
Post by Trebor » Wed Aug 27, 2014 2:09 am
kathichild wrote:... if anyone knows of another application, I'd like to try something else.
I've just tried Paul-L's De-Esser , a Nyquist plugin , and it seems to work* ...
Paul-L's Nyquist De-Esser plugin.gif (10.86 KiB) Viewed 10098 times
Nyquist Plugins are Audacity-specific , not OS-specific , so should work in Audacity on a Mac , ( I think ).
[ * high "frequency band" settings can cause Audacity to hang ]
Post by steve » Wed Aug 27, 2014 2:14 am
Trebor wrote:Nyquist Plugins are Audacity-specific , not OS-specific , so should work in Audacity on a Mac , ( I think ).
Yes, Nyquist plug-ins are cross-platform.
