Indicators of magnification
Help for Audacity on macOS.
Morley Chalmers
Post by Morley Chalmers » Thu Aug 21, 2014 11:15 pm
I'm editing out intermittent coughs during a lecture and frequently using Cmd-1 to enlarge and Cmd-3 to reduce.
Is there a visual indicator on screen showing the current level of magnification?
Is there a short cut to jump back the previous level of magnification?
Appreciated.
billw58
Re: Indicators of magnification
Post by billw58 » Thu Aug 21, 2014 11:41 pm
Sorry, no indicators and no "return to previous magnification".
However you could try command-mouse-wheel to zoom in and out (or command-one-finger-swipe on the magic mouse). It takes some getting used to but can be quite powerful.
Also, don't miss CMD-F (fit project to window), CMD-E (fit selection to window), and CMD-2 (zoom "normal")
See: http://manual.audacityteam.org/o/man/zooming.html
-- Bill
Reason: link to 2.0.5 manual
Post by steve » Fri Aug 22, 2014 1:46 am
Morley Chalmers wrote:Is there a visual indicator on screen showing the current level of magnification?
Look at the Timeline
Paul L
Post by Paul L » Fri Sep 26, 2014 3:40 pm
There IS a great convenience for zooming in to fix something, then zooming out to a previous level of magnification!
The Edit menu has "Region Save" and "Region Restore." I use Edit, Preferences, Keyboard to assign them to the w and e keys.
Then:
Select a section.
Type w.
Zoom in and fix something.
Type e, space, control-e (this has become a quick practiced motion for me).
So e restores the selection to what it was when you typed w. It does not fit the view to the selection, but ctrl-e with default key bindings does that. And I often type space between, to start playing the selection again before the view adjustment.
