AAC file in iTunes into Audacity
Help for Audacity on macOS.
Morley Chalmers
Post by Morley Chalmers » Thu Aug 21, 2014 1:56 pm
Step by step, how do I migrate some AAC files from iTunes 11.3.1 into Audacity 2.0.5 on a Mac running OS X 10.9.4.
billw58
Re: AAC file in iTunes into Audacity
Post by billw58 » Thu Aug 21, 2014 2:00 pm
Open iTunes. Open Audacity - a new, empty project window will appear. Drag and drop the tune from iTunes to Audacity - it will be imported into a new track.
-- Bill
Post by kozikowski » Thu Aug 21, 2014 9:21 pm
I don't think Audacity knows what AAC is without also adding the FFMpeg software.
http://manual.audacityteam.org/o/man/fa ... tml#ffdown
Post by kozikowski » Thu Aug 21, 2014 9:22 pm
I think it's also true you can't do that with Fair-Play copy protected files.
billw58
Post by billw58 » Thu Aug 21, 2014 11:27 pm
kozikowski wrote:I don't think Audacity knows what AAC is without also adding the FFMpeg software.
If FFmpeg is not installed Audacity 2.0.5 displays a warning, then uses QuickTime to import AAC files.
kozikowski wrote:I think it's also true you can't do that with Fair-Play copy protected files.
The only AAC files I have in iTunes are ones I've purchased. There is no problem importing. I believe Apple discontinued the Fair-Play DRM scheme years ago.
-- Bill
Post by kozikowski » Fri Aug 22, 2014 1:23 am
The split was if you paid the traditional 99c, you had FairPlay and it wouldn't let you copy, but if you paid $1.99, you paid for the music and the license to copy. Apple found a way to make a buck out of it — oddly enough. These are all iTunes purchases. Goodness knows if they're still doing that. I haven't bought music in a long time. My idea of a desirable work environment is the Public Library.
"That person's pulse is too loud. I want them ejected!"
waxcylinder
Post by waxcylinder » Mon Aug 25, 2014 10:25 am
The alpha 2.0.6 Manual has a section copied/transferred from the Wiki (and still remaining in the Wiki until we release 2.0.6):
Importing MP4/M4A files
MP4 and M4A files can be imported directly into Audacity:
* Windows/Linux: Follow the Windows or Linux instructions to download and install the optional FFmpeg library. Then use File > Import > Audio.
* OS X: Just use the normal File > Import > Audio command. current Audacity now requires OS X 10.4 or later. Users on OS X 10.3 can download the previous 1.3.3 version instead.
Then import the converted files into Audacity normally from the location stated in iTunes.
Post by Gale Andrews » Mon Aug 25, 2014 6:12 pm
I think most or all recent songs will be DRM-free, and most old FairPlay songs will be upgradeable to non-DRM. The upgrade fee is 30 cents according to Apple Unveils Higher Quality DRM-Free Music on the iTunes Store .
