Quickest Way to Copy Selection to Adjacent Track?
Help for Audacity on macOS.
cpsmusic
Post by cpsmusic » Tue Jul 29, 2014 1:56 am
Hi,
Just trying to work out the quickest way to copy a selection from one track to another track and have it line up exactly with the original?
I know I can do this a couple of ways:
1. Make a note of the selection start value and then reset this when the new track is selected so that the paste point is right.
2. Mark the selection with a label and then use the boundary guides.
Both these seem a bit slow - is there a quicker way - something like the Duplicate command but that doesn't create a new track?
Cheers,
Chris
Re: Quickest Way to Copy Selection to Adjacent Track?
Post by kozikowski » Tue Jul 29, 2014 2:05 am
We were good to right about there.
....What.......?
Give us that again but use different words. You want to copy and paste into a new track without creating a new track.....?
cpsmusic
Post by cpsmusic » Tue Jul 29, 2014 2:29 am
Sorry I'll try to be clearer.
Say I have a file containing multiple sections that I need to edit separately (e.g. multiple songs from a radio show I'm editing).
What I'd like to end up with is one track containing the complete original show and a second track containing just the songs aligned to their original positions. The problem with Duplicate is that it puts each song on a new track.
Does that make sense?
Post by steve » Tue Jul 29, 2014 2:36 am
cpsmusic wrote:The problem with Duplicate is that it puts each song on a new track.
Why is that a problem?
cpsmusic
Post by cpsmusic » Tue Jul 29, 2014 2:53 am
It's mainly a workflow issue - I tend to lose track of them on the screen!
Also, there are other things that I have to edit out of the original track and group together - it's simpler if I keep similar items on a dedicated track (e.g. live songs, songs, interviews, stings, etc.)
Post by steve » Tue Jul 29, 2014 4:25 am
Several tips that may help:
Collapse / Expand tracks
http://manual.audacityteam.org/o/man/au ... l#collapse
Collapse / Expand all tracks
http://manual.audacityteam.org/o/man/vi ... l#collapse
Any number of tracks may be "mixed down" into a single track at any time, using "Tracks > Mix and Render". The mixed track appears at the bottom below all other tracks.
A direct answer to your original question. Using keyboard shortcut (really quick when you become familiar with the keys)
  1. Make the selection in one track
  2. Ctrl+C (copy)
  3. ENTER (toggle the selection off)
  4. Down cursor key (move focus down to the track where you want to paste)
  5. ENTER (toggle the selection on)
  6. Ctrl+V (paste)
Also see: http://manual.audacityteam.org/o/man/ed ... audio.html
cpsmusic
Post by cpsmusic » Tue Jul 29, 2014 4:46 am
Bingo!
Many thanks!
It's the use of the Enter command that fixes the problem I was having.
Cheers,
Chris
