Random, unintentional, subtle changes in pitch
Help for Audacity on macOS.
Re: Random, unintentional, subtle changes in pitch
Post by Gale Andrews » Sun Jul 06, 2014 11:52 am
squareshot wrote:I swapped up to the Retina from a MacBook Pro this Spring, and ran into some trouble with my setup, as I mentioned. A majority of plugins crash the program now, but I really can't complain, my lonely user install has worked very well for several years; there were some plugins I couldn't try, since they needed a system installation, but there really was a lot that could be used until [presumably] Mavericks.
Thanks for the crash reports.
Some of the reports don't implicate specific plug-ins at all. Is there anything specific you do with these plug-ins to cause the crash, like using them on very long tracks or at specific settings? Or does every use of the plug-ins cause a repeatable crash?
Four specific plug-ins are mentioned in the crash reports. We can try those sometime as long as they are free and don't require iLok.
patrickcarbonell
Post by patrickcarbonell » Sun May 10, 2020 7:18 am
Actually, this also happens to my Asus with Windows 10. After a successful perfect-pitched recording, after several entry into other tracks, I noticed my first entry of recorded voices warp and subtly dip in pitch. There was even an extent it sounded like a ghostly thing because of the vibratos. Haha.
Such distortions and warping added extra time to my editting since I have to creat a new trach to use as my dummy recording area and copy and paste it to the old warped sound.
