What Are These Red Lines?
Help for Audacity on macOS.
cpsmusic
Post by cpsmusic » Tue Jun 17, 2014 10:44 am
Hi,
Audacity is showing some red lines at points where I've removed some audio from a track (see below). Show Clipping is off.
Red Lines.png (31.26 KiB) Viewed 1112 times
There doesn't seem to be any clipping at these points. What are these lines indicating? How can I remove them? Are these mentioned in the Manual?
Cheers,
Chris
Re: What Are These Red Lines?
Post by Gale Andrews » Tue Jun 17, 2014 11:34 am
Turn off Cut Lines in the Tracks Preferences . Cut Lines are not enabled by default.
cpsmusic
Post by cpsmusic » Tue Jun 17, 2014 12:52 pm
Thanks!
