Hi,
When I try to export to M4V or MP3 for iTunes use, I get a dialog that it's searching for a library to do it, but it cannot find it.
Can I download the library somewhere, or what is my workaround?
Thanks much, apologies if this is already addressed elsewhere.
Have a great weekend,
David
Export Edited File to M4V or MP3 Requires Plug-In
Re: Export Edited File to M4V or MP3 Requires Plug-In
Two, actually, one for MP3 and one for M4A (Audacity will not export video).
There is a third way. You export as WAV and convert inside iTunes.
This is the Lame software for MP3:
http://manual.audacityteam.org/o/man/fa ... encoder.3F
This is the FFMpeg software for M4A:
http://manual.audacityteam.org/o/man/fa ... Library.3F
